Portable Instrument Stand, Foot Rest & Stool In One!
Ever since I’ve started using the Compact for most of my gigs, I’ve missed the L1’s guitar hanger that was so cool. But today, my new toy arrived and I had to share it with anyone who digs the idea of having a portable stool, footrest and stand. I LOVE it!
http://www.farleysessentials.c…sp?specific=jogsfoj0
Wayne,
That looks very interesting!
Is the footrest adjustable in height? One issue I run into consistently with stools with footrests, is that the footrest is always either too low or too high (usually too low).
Stu
No. It sits comfortably enough for me. I’ll use it at a gig on Saturday and get a better feel for it. The stand is very secure with the couple of acoustics I’ve put in it and the seat is comfortable, though the padding is not very thick and long spells might be an issue.
I guess the first version didn’t have the footrest and they must have responded to requests and added it.
I’ve used that Stage Player II stool since last November but I’ve had issues with the construction. I’ve twice had to take it to a local welder when the lower horizontal supports came loose. All four connections have had to be re-welded, resulting in an extra 40 dollar cost. And I’m not a huge guy, I weigh about 210 lbs. I use a Porchboard, a looper and a harmonizer though, so there’s a lot of movement going on with my feet that probably inadvertantly jostles the stool a bit, resulting in the joints coming loose.
Hi Wayne,
I thought I’d hold off for a day before diving in on this.
I’m performing standing up these days but when I’m seated often I use one of these.
Quik Lok D749
–== click the picture to see it in context ==–
at 17 pounds it’s more to carry than the Stage Player II, and it doesn’t have the integrated guitar stand (which is nice idea) but it is infinitely adjustable, very comfortable, and as far as I can see - indestructable.
Here is a close-up of the D739 (same thing without the back rest).
It travels like this.
Now you’ve got me thinking about having a hercules style guitar hanger welded to the back.
Nah, I’m still one of those guys - “If it’s not on my back, it’s in the rack.” Translation - If I’m not playing my guitar, it’s in the case. Case closed. Maybe that’s why I missed the value proposition in your original post.
I'm performing standing up these days but when I'm seated often I use one of these
Quik-Loc D749
Unfortunately, I own one of the Stage Player II's and it is pretty flimsy. The padding attached to the very thin top plate is very minimal. Unlike PatrickM, mine hasn't broken the welds yet, but it was not very comfortable after a 4 hour gig. The height is too low and it is beginning to loosen up. I added a piece of plywood, thick foam and covering to the top to raise it up a bit, helps somewhat. I may just use it in my studio.
I was looking at the 2 DJ chairs that were being discussed and notice, 1 from Technical Pro is about $60 (with what appears to be light padding) and pretty light (11 lbs) that makes me nervous and the other from Odyssey Innovative Designs was $79 about 30 lbs shipping weight, in comparison to the Quik-Loc, (about $94-113) that seems rather heavy.
I have seen a friend using the Quik-Loc and it looked very sturdy. I forgot about it when I purchased the Farley Stage Player II. Probably the biggest problem is that it sits so low, I think about 24" vs the 30" of a regular bar stool. The Quik-Loc and the DJ models will adjust up to 33", giving you the stand up look.
The Odyssey and the Quik-Loc both appear to have better padding and the Quik-Loc has a 5 year warranty. Although the Quik Loc D749 is quite expensive, it seems that "You get what you pay for with it".
ST, how long have you had the Quik Loc chair?
Is it really comfortable for several hours?
I’ve used the one with the backrest, ST’s first pic, for several years now. I think it’s great.
I often play for 3 or 4 hours, rarely a break (I know, nuts) and the chair remains comfortable. Sturdy too, hardly any wear, probably 100 gigs. Only drawback is that it’s not super portable, but once I get it there, I SURE AM GLAD I have it, and it’s not too bad to carry anyway.
The guitar stand aspect of the other one seems pretty cool. But, for me, I always have two guitars, and I have nice looking Taylor wooden stands for them.
I only sit for two songs or so an hour. For players who sit a lot, maybe ST’s chair would work better. Time will tell, but I’ve got a feeling this new Farley chair will be a good fit for me.
Hi Joel,
I’ve had it for years. I use it mainly in my rehearsal space when I’m woodshedding. These days when performing - I’m almost always standing. It’s harder to play acoustic guitar that way but much better for my singing.
Back to the chair - I think Mike’s comments pretty much mirror my own except that even when practicing - I’ll rarely play for more than 60 minutes straight. The old hands aren’t what they used to be.
Unless I get completely lost or end up playing with a succession of partners at some kind of event, I try not to play longer than 40 minutes in a set. I’d rather leave them wanting more than less.
About the height - If I am sitting, I like to sit as high as possible as long as I can reach and use my PorchBoard. For me that’s 28-30" for the seat pan and I have the foot rest at 12" (the maximum it will go). I just tried it - and you can put the seat up to 34" which is way too high for me (can’t reach the floor).
I just had a gig Monday, that turned into 6 hours and Yes, I take breaks every hour. My hands were so sore, I couldn't even hold a pick very long during a couple of sets, so I just strummed with my fingers. My voice was a bit tired, but I had off till Thursday to recover.
I alternated between standing and sitting for a number of different songs. I usually stood up when I used my Digitech VL4, since I have it set to momentary. Several of the venues have a decent bar stool, but I think that Quik Loc makes a lot of sense, good adjustments, quality and should only have to buy once. I almost thought I could get away with the Odyssey at $79, but I'd rather play it safe.
