Hi there
I have a problem with an amplifier that keeps telling me "corrupt firmware" what can I do? I have tried many times to reload the firmware with the latest version, but the result is the same.
Kamil Barca
Roma
Italia
Hi there
Kamil Barca
Roma
Italia
Thanks for the reply. I already knew the procedure very well. but even so I have solved the problem it always gives me the same error for the sake of accuracy I use the latest software and firmware version. thank you Kamil
Thanks for the reply. when I do the procedure it returns to me as before I do not know what to do thank you Kamil
Hi Kamil,
It is strange that you're getting a corrupt firmware message even without Recovery Mode active, as this message is only intended to appear when the amp is in recovery mode.
So when you attempt a firmware update, does it stall or stop half-way through?
If so, there may be an issue in Windows with language selection (CSD 5.7 only).
We've heard reports in the past that when Windows has a default language/region of anything other than English / US, this can cause PM firmware to fail in ControlSpace 5.7. If this happens to be the case, then you can change the setting, or just try CSD 5.8-5.9.
Thank you,
ChrisJ-at-Bose
ok I try
Hi Chris
then no the message appears when I do the recovery procedure
but no changes nothing keeps restarting always.
and now I see at the end the message: "error console"
