Pro 32 as a mixer
I am needing to know if I can use my Pro 32 power base as a stand alone mixer for extra mic inputs using the line out to my S1 Pro.I have a gig that requires minimum setup space.
Hi jdpuentejr!
You could use an L1 Pro32 to sub-mix channels before going into an S1 Pro, or vice versa.
Bear in mind, though, that the line outputs on both speakers do not have an on-board variable gain, so overall volume level of the sub mix would be set on the destination speaker.
