Problem with Bose L2 bass
Hi I use the Bose LII bass (larger size) and often it just starts buzzing and doesn’t produce the full bass sound. I’ve discovered that this is often due to the power not being powerful enough to drive it. If I plug it into a new power source it often restores the problem. Has anyone else had anything similar or can shed any light on it for me? Many thanks
Hi antonywolfson,
I’m sorry that you are having a problem with your B2 bass module. This sounds quite unusual.
Normally, if the power is low, the power stand will shut down, not keep working with low quality sound.
Let me suggest that you write to Bose in the Ask Bose For Help forum area of the forum.
Just follow the link above and post the same message.
