I have a pair of Bose QuietComfort earbuds. On 3 occasions now they have failed where one or the other earbud has no light on it when you open the case. The other earbud has a solid white light and does not connect to bluetooth.
This has happened after charging the case, i.e. the case is fully charged (5 white lights on the front) and the earbud has been charging with it.
No amount of "holding down the bluetooth button for 30seconds" corrects the issue.
On the two previous occasions I put the case on charge again overnight - and it was working again in the morning.
Bose product name
Country
UK
Not available (phone can't connect to earbuds)
4.5.4
What devices were you using that were affected and what version are they on iPhone 12 Pro, 14.6
Charge the case
What environment do you experience the issue in? not relevant
Within one week of purchase. this is the 3rd occurance.
Hold bluetooth button down for 30seconds
