PLEASE could some help. I am just not getting the quality sound I know bose gives.
I loop (with the RC-300 from boss) and harmonise with the TC Helicon Play acoustic. Please can someone advise how I connect this setup to the T4S so they all work in harmony
. At the moment I get buzz and feedback on the mic which just doesnt seem right for such quality sound.
PS for my guitar I have a Martin (Ed Sheeran Little Martin) and a Sennheiser XS 1 mic(if thats any help)
Can you isolate whether the hum is coming from the RC300 or the TC or both?
Looking at the manual, it appears that the RC300 outputs are unbalanced connections. Unbalanced connections placed near A/C fields can result in hum. Try moving the power strip away from your setup and see if you still get hum.
Those are the first two things I'd try.
Thanks Chet ill try that. If I could get some suggestions on how to plug in the cables to get the best sound it would be great too i.e. which cable should go where to get the voice and guitar sounding great. I get it to work but I don't think I am plugging the cables in the most optimal way between the pedals and tone match.
P.s.
I had to buy a voltage converter we use 220v and I have an imported American unit that is designed for 110v( I'm sure that contributes to the problem) but I also get the vocals feeding back for small volume adjustments where the guitar is pretty stable in terms of feedback(or it may just be softer and that's, why it doesn't, give as many problems IDK. HELP
