I'm looking for advice on how to do this? I'd like to connect my T1 mixer to my computer to record using my L1 Model II PA system. Anyone had experience with this?
Hi, J.
J posted:I'm looking for advice on how to do this? I'd like to connect my T1 mixer to my computer to record using my L1 Model II PA system. Anyone had experience with this?
Have you tried connecting the T1 to the computer using the USB port?
Here's an article
Once you've established the connection, you should be able to use software like Audacity or GarageBand to record.
Will this work with Logic Pro X?
Also make sure that you set the bit rate on your computer to 48kHz. I have just made a "stereo" [2 ch] recording using Audacity on my MacBook, and simply selected "Bose USB Audio" as the input, plus Format: 48000 2-ch 24 bit [Audio Midi Setup]. Not sure that GarageBand will work properly, since it defaults to working at 44.1kHz – see article above linked to by ST.
PS I have now also got this to work in Soundtrack Pro, should you have an old copy of that …
