I was wondering if it is possible to remove the plastic foot (base) of the L1 Compact? I have a tight corner with limited real estate and I figure I don't really need that extra base for stability and want to remove it to save some space. Thank you.
Please do not remove the plastic foot (base) of the L1 Compact. The plastic foot secures the grilles and the connector plate for the speaker array/extensions. The grilles could rattle and you will make the connection to the speaker array exposed and vulnerable to physical damage. Please note; removing the base will void the warranty.
