wrote:
Thank you for the very complete answer. So here's one of my issues in staying with Bose. We have three SA-3 amplifiers driving a pair of Bose speakers elsewhere in our setup. I do not see audio outputs on the Bose 600 or Bose 650 that could drive these remote zones. How would a new Bose AV setup be used in our case?
Thanks again for your advice and willingness to share your knowledge.
Glee
The SA-3 is designed to be controlled via a Boselinked receiver like the AV18/AV38/AV48/MC1/AV35 (the AV35 was redesigned in 2013 and removed Boselink). The remote communicates to the bose receiver and tells each room to power on/off, volume up/down, select the audio source.
Without the Bose receiver, things do get a bit tricky, but apparently, it is not impossible. The SA-3 has 3 features on the back of your amplifier that will allow you to use a local source for music:
- An RCA input.
- Dipswitches to modify features within the amplifier.
- A VCA connection for volume (I am unsure if VCA also controls power or not).
So I did a bit of googling and I found a post on Reddit, one on a different forum, and another on this forum. In the last one, someone linked to a YouTube video showing how you can use this amp without a Bose receiver.
I think it is easier to keep the Bose receiver or upgrade to the Boselinked version of the AV35 (please read over this post and see if you can upgrade your receiver). But the good thing is you have a solution if you wish to remove your Boselinked receiver from your home 🙂
wrote:
I made a killer Dolby Digital 5.1 surround sound system using a Bose Acoustimass 7 and Bose Acoustimass 5 along with a Klipsch subwoofer and Onkyo 7.1 surround sound receiver. I used the Bose Acoustimass 7 for front left, center, and right and use the Bose Acoustimass 5 for the rear left and right.
You could use your existing cubes with any Bose Acoustimass module that is not part of a Bose music system that requires a Bose console. You can find what you need on eBay.
The only drawback to that specific setup would be you'd have two passive subwoofers and a third powered subwoofer on the ground. More than I would personally wish to have around the room if I could avoid it.
I would still hold that if you wish to go for a 3rd party receiver-based system it is better to purchase an Acoustimass 10 or a second hand Acoustimass 15 (if you wish for a very powerful sub and you can find one). I talk about them briefly here.
I hope that this answer helps solve your questions 🙂
