Running L1 model II AND F1 together from Soundcraft mixer
I connected my L1 II with B2 with xlr from left main out on Soundcraft mixer into the analog input on the stand, using an xlr to 1/4 inch adaptor, and an XLR out of mixer's right main to the F1. No signal went to the F1. It was not a cable issue--it seems the L1 hijacked the entire signal. Has anyone else run into a similar situation? What did you do for a fix?
Hey jimmymac59,
This sounds like it could be the Soundcraft mixer only outputting through the mono (left) output, as if the right XLR isn't detected.
What happens if you switch the XLR cables on the mixer's stereo outputs - does audio only come through the F1?
