Last weekend I used one of the s1 speakers inside connected via cable to my laptop with no Bluetooth and laptop WiFi turned off.
Outside on a deck I connected my other s1 to a iPad via Bluetooth using my phones hotspot.
I started noticing interference from the outside set up causing issues with the inside hard wired unit. The music would not play or it would play both music from both sources (laptop and iPad). I double checked that WiFi indicated that it was turned off. Any clue?
Hello jcflow1!
Thank you for your post. If one speaker is only set up with a wired connection to a laptop, and the other is set up with a Bluetooth connection, it would not be possible for the same audio to play on both systems unless they are daisy-chained.
Are the speakers connected to each other with the 1/4" jack via the line output?
Which audio sources would you normally play on the speaker from the laptop and iPad, e.g. Spotify, stored music library?
