S1 Pro buzzing noise
My S1 Pro has started making a buzzing noise in the treble frequency. If I turn the treble all the way down it almost goes away. If the treble is turned up it is very noticeable. The volume is at 50%. The problem is there plugged in or battery.
S1 Pro
USA
Hello Ciccelli,
The S1 Pro carries a 2 year warranty.  I would contact Bose support to determine what the next steps should be.
Customer service: 1 (800) 379-2073
Technical support: 1 (800) 380-4831
