Hi Everyone.
There is a new firmware release 7.1.7 available today. All firmware updates are cumulative. All prior updates are included in the most recent version. Bose recommends that you keep your firmware up to date.
Release Notes
- Maintenance Updates
- Supports Auto-Off power-saving control via Bose Connect App.
- in Bose Connect Settings (gear icon) | Auto-Off to see the options to turn this on/off
As you may know, the S1 Pro system will go into power-saving mode if left idle but powered on for more than an hour. The blue LED on the front will blink. The system will automatically wake up if when an audio signal is present (channels 1, 2, 3 or via Bluetooth).
With firmware version 7.1.7 you can disable/enable the power-saving mode by using the Bose Connect app.
- In Bose Connect, at the top right of the screen tap the gear icon (settings)
- Then tap Auto-Off
- Then tap ON or OFF depending on what you want the S1 Pro to do.
The fastest way to get the new firmware is to use a PC or MAC and follow the instructions here: S1 Pro System Firmware Update
OR
If you use the Bose Connect app. It should detect that there is new firmware available and display "Preparing product update".
If you see this, make sure your S1 Pro is connected to AC power. You can listen to music or do other things with your device as long as you don't shut it off or lose your internet connection. This process can take quite a while depending on the size of the firmware update file.
When you are ready to update the S1 Pro system make sure the S1 Pro is connected to AC power. Then, tap UPDATE. This part should be done in under 5-10 minutes.
You will see the progress indicator.
When the progress indicator stops you may be prompted to rename your S1 Pro. Change it or leave it as is. That's up to you.
Then follow the screen prompts.
If you have difficulty with the firmware update process please call Bose Support. They will be happy to walk through the process with you.
(U.S. and Canada only)
Other regions
