Bose product name
Bose Soundlink II
Country
Italy
(3.0.5)
(ios )
Android 8.1.0, iPhone 5SE on iOS 14.4, MacBookPro 11.3.1
Currently the Soundlink doesn't play any sound a part from the its own voice. I can restart it, reset it, and I hear the voice, but when I pair it with any device it doesn't do anything. It used to work. I cannot understand what has changed. I tried to reset the device list by presssing the bluetooth button from ~10 sec. I did it few times. Nothing changed. It was recognising the device, but it would play any sound. Last time I reset everything I manage to sk*** up everything as it pairs with my devices but the Bose Connect app is not able to recognise the Soundlink anymore (although it's paired). I've already spent 3 hours looking in the forum and reading/watching all the troubleshooting guidelines. I'm fed up. It seems ridiculous to spend 79€ repair something clearly comes from a software issue, not a hardware one.
Where do you run into the issue?
It did work correctly. Very happy for several years.
Read all the guidelines. I've try resetting the bluetooth pairing list many times, I tried increasing and lowering the volume, I tried restarting the device, I tried uninstalling/installing Bose Connect.
