What audio sample rate is supported by the Soundlink Mini II via Bluetooth connection?
The drop-down menu under the Windows 10 speaker settings only shows 44.1kHz. The drop-down menu is grayed-out, so no option to select another sample rate. I'm looking for 48kHz support. If the SL Mini II supports it, then I can rule the speaker out as the problem. Except I cannot find this detail so far online.
Thanks!
