SP24 unit error message ´not configured as a DSP'
Hi all,
I received a message coming from a SP-24:
SP-24 IS NOT CURRENTLY CONFIGURED AS A DSP
I’ve never seen that kind of error messages before.
The message appears when I hit the GO ONLINE button on the Editor Software.
I get the green light on the software, so the USB connection is fine.
I appreciate any help on this issue.
Thank you,
D. Cárdenas
Hi all, somehow the SP 24 firmware update fail & now my software cannot recognize the SP 24 (hardware).
On the hardware, the display shows "waiting on firmware update"
When I power cycle, it still stuck at "waiting on firmware update", how to revert back?
Appreciate help from everywhere.
Hi Bernard,
I understand that you already have sent the SP-24 to Christopher?
I will work with him to see if we can reset the unit.
Best regards,
Hi Arno,
Yes done!
Cheers!
Hi Arno.
We are experiencing this issue on a local unit. Can you share the reset/fix please? Thanks.
Hi Steve,
Which issue are you experiencing?:
"SP-24 IS NOT CURRENTLY CONFIGURED AS A DSP"
I would advise to send it for repair or replace the unit.
