I'm using two systems and my Tonematch with just a mic on CH 1 and laptop tracks with USB on CH 4/5. Can I somehow send the mic to one system and send just the tracks to the other? Hopefully this is not too dumb of a question as it would be nice to have complete vocal and music separation.... thanks in advance for all and any help/advice!
You would simply pan vocals to the left and your tracks to the right.
zatoichi posted:I'm using two systems and my Tonematch with just a mic on CH 1 and laptop tracks with USB on CH 4/5. Can I somehow send the mic to one system and send just the tracks to the other? Hopefully this is not too dumb of a question as it would be nice to have complete vocal and music separation.... thanks in advance for all and any help/advice!
Is your ToneMatch a T1 or a T4/T8S?
Yes, you can do that.
Hi, zatoichi.
Long time, no see.
Unless you've gotten a new ToneMatch mixer, you probably have a T1.
You can set up the microphone into T1 Channel 1 as usual. Connect the T1 to the first L1 as you normally do with the ToneMatch port and ToneMatch cable.
For the tracks routed through USB to Channel 4/5, set up an Aux send with Tap Point set to PRE with EQ and FX. Then you can Mute Channel 4/5 and the sound will go only to the Aux output.
You can read about that here
Now you can connect the T1 Aux output (yellow box above) to the second L1.
The downside to this approach is the T1 Channel 4 volume control won't affect the volume of the tracks. You can still control the volume by
- Using the volume control on the computer or the application you are using to play the tracks
OR - Turn the Rotary Selector to Aux, Press the CH EDIT button for Channel 4/5 and change the level.
Hi ST...good to know you're still out there dispensing great advice as ever, and yes, this helps immensely,
Many thanks!
Z
Thanks to all for your input and expertise....it's much appreciated.
Z
Lynn 6 posted:You would simply pan vocals to the left and your tracks to the right.
I'm sorry I didn't realize the T1 only had one master out in one of auxiliary. I guess I should have asked that question. I have T8
Which has 2 quarter and two Canon right and left outputs.
No worries and thanks for the response!
Z
