Sub 2 extension cable
Hi - Currently have a Bose L1 M2 and use a long speakon cable to set the B2 off to one side of the stage as the bass would cause a bit of feedback when set behind the musicians. If changing to L1 Pro 32 and the Sub 2, is there an elongated Submatch cable available to buy?
Hey herge,
The SubMatch cable is only available in length 5ft (1.5m). However, you can also connect the L1 Pro32 and Sub1 or Sub2 bass modules using an XLR cable plugged into the line output.
