This is a new unit for me with a bose compact and a T1. I want to use Tonematch on channel 1 with a Sm58 and pre amp to my Boss RC-30 to the mic feed. My guitar thru my Amplifi TT into channel two with acoustic and then again pre amp to the Rc-30. I know I can still take my main output on the T1 to channel two on compact unit. I also use a double 1/4 to RCA's from RC -30 looper and bring that in on channel two also. I want the T1 to feed those wonderful sounds direct to looper.
I was wondering if anyone had any thoughts on this, would you do the same?
The T1 Preamp Outputs are post-trim only. That means there's no T1 processing at the Preamp Outputs. (No ToneMatch Preset, zEQ, ParaEQ, Effects or Reverb). If you are using any of the T1 processing - then the looped versions of your voice and guitar will sound different in the loops than the direct sound from the T1 Master Output to the L1 Compact.
I don't have an RC30 (nice unit) anymore, but when I did, I sent the T1 output (the full mix) to the RC30 and the output of the RC30 to the L1 Compact channel 2 with the ToneMatch switch set to Line Level.
compact/ T1 and a mackie ProFx4/ Boss Rc-30 looper and mice and guitars
Loving the tone from the T1 on the Mic and feed my guitar to a Amplifi TT in to channel 2 and connect to tablet. I still haven't added the looper to the equation and really don't want the Mackie in the layout. So, sitting here banging my head its been a long time for me setting up any pa's. Some ideas would be great, thanks
… I want the T1 to feed those wonderful sounds direct to looper.
Hi Big Rick, two suggestions of different options follow.
First why don't you send your T1 channel 1 SM58 output (with Tonematch effects) direct to the looper using the AUX output, and then back in again on channel 4/5?
Put main selector to 'AUX', then 'CH Edit' for CH 1 set Level 50% (left twiddle) and 'Tap' Pre (centre twiddle knob). Mute CH 1 and/or set Vol knob to zero, and use Ch4/5 Volume for adjusting your Mic level in the mix. This would just loop your voice.
Outputs: Aux => Looper, Master => Compact
OR if you want to mix your voice and guitar together before the looper you could be a bit counter-intuitive –
Use CH1 and CH2 to mix your mic and guitar as usual, send the Master output to the looper (as ST suggested earlier), bring this back in on, say CH 4/5 and only send that to the AUX output: which you then connect to your Bose Compact.
So on the AUX selector you make sure that CH1, CH2, CH3 are set to Level 'Mute', and then set CH 4/5 to Level 50%* and Tap 'Dry'. And this time Mute CH 4/5 and/or set Vol knob to zero.
Outputs: Master => Looper, Aux => Compact
* you would be able to adjust the sound volume either here or on your Compact, not usingT1 volume controls.
Be quite careful to avoid howl-round (when setting up) if you try the later option.
Following on from my earlier I have thought of a much better way to do this!
I have had a look at the RC-30 looper so see that it has two inputs & pedals. So presumably you'd like to send it both Vox & Guitar unmixed?!?
A Minor (or Major) change to my above reply - but a similar concept - is that you send your Mic (SM58) processed out of Aux 1, and your guitar out of Preamp 2 to the RC-30.
Output: Aux 1 => Looper Mic IN.
CH 2 Pre Out => Looper Instrument IN.
Output: Master => Compact
Then send your looper output back to T1 CH 4/5. [Your Master OUT does go on to your Compact as you'd expect.]
RC-30 Looper => CH 4/5 IN.
The BIG plus point is that you can now adjust levels of everything on the T1; the T1 does the ToneMatch vocal processing, and your Amplifi TT the guitar processing. Now no channel mutes should be lit - just use the Looper provided mix and the T1 Vol knobs for each channel (Mic / Guitar / Looper).
BTW I would suggest you set the level of CH 1 for the AUX Out (to the Looper microphone input) at say 10% as a starting point - saves using a pad to get this feed down from Line to Mic level.
