T1 Channel 3 Not Working
It appears that I have the channel 3 issue that others have ran into.  Initially, it was noisey but now the sound via channel 3 only is very faint.  I really love this system; please help.
Hello, Ron,
I am sorry you are having trouble with your T1®. It sounds like your T1® will have to be serviced.  Please call us.
(U.S. and Canada only)
Thank you,
Bose Pro Community Admin
PS
We're in tomorrow and we're out on Monday for Labor Day.
My T1 channel 1 went kaput... I was quoted $800 for a replacement PCB from a Bose Technician - which I refused.... I stored the unit for several years, then I recently powered it up and Channel 1 works perfect - the problem has now transfered to channel 2.... W.T.F. ??
Did you have any success rectifying your channel 3 ?  ... If so, how ?
Hi glenn33,
Sorry to hear you're seeing an issue with your T1. Does the issue continue when all FX on channel 3 are muted?
If you haven't used the T1 in several years, I recommend performing a factory rest to see if this resolves the problem:
  1. Power on your ToneMatch mixer
  2. Rotate the main selector knob to Scenes
  3. Rotate the Select knob (the leftmost knob under the display) until Factory Settings is highlighted
  4. Press the Select knob to select this option, then again when prompted to confirm.
