T1 or T4S with L1 Compact
Since the L1 Compact does not have that Tonematch Port connection between the unit and the T1/T4S engine like the Model 1/1S/2 does, so it has to be connected via its 1/4" input.  Does that cause any inferior performance of the T1/T4S?
And second question, can the T1/T4S be used with other non-Bose speakers and still give good performance as with the Bose L1 speakers?
Thank you.
Hi, duke.
duke posted:
We can't know how an L1 Compact would sound if it had a ToneMatch port. However, Bose engineered the L1 Compact to be compatible with the T1 using a balanced cable connected to the L1 Compact Channel 2.
T1 to L1 Compact
¼ Inch Tip-Ring-Sleeve (balanced) to ¼ Inch Tip-Ring-Sleeve (balanced)
A balanced connection is preferred and will provide better noise rejection over greater distances than the unbalanced connection.
Tip-Ring-Sleeve to Tip-Ring-Sleeve
¼ Inch Tip-Ring-Sleeve (unbalanced) to ¼ Inch Tip-Sleeve (unbalanced)
This should work fine but a balanced connection (immediately above) is preferred especially if you will have cable runs in excess of 20 feet (6 meters) or if you hear line noise, hum or hiss.
Tip-Sleeve to Tip-Sleeve
See T1 to L1 Compact for details.
T4S to L1 Compact
Bose engineered the T4S/T8S to be connected to other Bose products as a replacement for the T1
Use a balanced cable connected to the L1 Compact Channel 2. See details about cables above.
See: T4S to L1 Compact for details.
Thank you.
We have an article - please see T1 without L1
This article is equally applicable to the T4S/T8S.
All set?
