Awhile back I read a comment by Cap where he much preferred stereo with two L1s over mono with one L1.
Felt he was talking about Model 1.
Curious if there is this much improvent using one T1 with two L1s in Model 2?
Maybe I am unclear on this but here I am asking a question.
Will appreciate any input on it.
I prefer the T1 sound card to any out there but some would argue, including Cap and JD Bass.
That said, I do not use the T1 for stereo because doing so changes the functions of the dials and makes it, for me, difficult to operate.
I am running Model 1’s not 2’s but I can’t imagine there would be much difference. Stereo simply sounds better and the phase cancellation issues of using 2 L1’s in mono are is eliminated.
For some additional info on these topics check out these links. I hope this is sufficent until someone with more knowledge on the subject jumps in.
Phase Cancellation
Stereo & Mono
Thanks Lou.
I too hope someone has tried both methods and will help with this.
Lou - Which Mixer do you use when using the L1’s in stereo.
Thanks.
Just realized that my question was never answered.
Does anyone use stereo with one T1?
That is one T1 and two L1s.
Has anyone tried this?
i have used the T1 in stereo with two L1M1s. it’s sort of pointless for me. i use a DJ controller/mixer that would allow for stero set up. you don’t get to use any other inputs since the T1 is setup just for sending the stereo source to two sides. you can’t insert a mic and be able to control anything more than the trim. so if I need stereo and inputs I use a stereo mixer. if i need stereo without more mic inputs I just go from my dj controller to each L1M1
