T1 tonematch popping noise
i am getting a pop noise everytime my level indicator light goes on and off on channel one of my T1 tonematch. None of the other channel do it - just happening on channel 1 ?
Hi Rob,
Thanks for joining the community.
I'm sorry you're having a problem with Channel 1 on your T1.  Do you have the same issue if you move the input source on Channel 1 to Channel 2?
yes i have tried every channel and every level of input. I also restore to factory setting and kept all the setting flat on the channel that is having the issue. I am afraid it has something to do with the level indicator light on the channel. i only have the noise when the light goes on or off. It's like a static pop sound not a constant fuzz in the channel
Hi rob,
It sounds like the unit may need to be serviced. Please call Bose tomorrow and they will help.
Call Bose Technical support at 1-877-335-2673 (U.S. and Canada only)
Monday-Friday: 9:00 AM – 9:00 PM ET
Hi, I know it’s been several years since your post but hopefully this will help you. I recently had this same issue with Channel 1 on my Tonematch 1. The way I resolved the issue is to change the setting on your Noisegate under Comp/Gate. Your thresh setting is probably set at 70dB. Try changing it to a much lower number, like maybe 30 and see if that helps.
