T4S Scenes - Jacks Out
Using a T4S, latest firmware and no problems but seeking advice..
I am to do a gig where I want to plug my T4S into a house system.
I realise I can do this via the two TRS out jacks on the back - but here's the thing - I did this one before and got very little signal out of the jacks and in the end had to put my mic into their desk and same with ipad - by-passing my T4S.
Something I did not do was change the scene, I was using a favourite stereo scene as normal, but a friend showed me a "Jacks Output" scene i'd not seen before and therefore not configured.
When using the jacks output is it necessary to dial in the jacks output scene?
I did think that I could use my two L1M2 sets rom the digital outputs and then take a feed from the analogue jacks to a desk - but my experience so far has shown me I can't.
I have a gig this Sunday plugging into a house system - can I use the analogue jack outputs with a normal scene or do I have to select it to get content through them?
Dave
Hey Dave!
You should not have any issues running stereo out from the T4S to the House Desk. I guess there must be some other variables to investigate if the previous attempt at doing this was unsuccessful. A few questions to note:
  • Was the Trim at an appropriate level for your Mic/Instruments?
  • Was the master level set appropriately?
  • Did you also try the setup with the AUX Outputs? (If so was the AUX Output level adjusted Appropriately?)
Try checking out this Gain Staging Demo - https://www.youtube.com/watch?v=8Dhped9GCsg
Thanks David
Have since run several shows using the jacks out without issue. I guess the first time I tried - which was into a large mixer being run by a guy donating his services to a charity - I / he got something wrong.
Cheers
Dave
