Hi, xytiz.
xytiz posted:
THANK YOU VERY VERY MUCH ST for your time and patience to clearly explain, I appreciate you put volume levels also, Lot of attention to detail, Really helps a newbie like myself.
You are welcome.
I should have mentioned a related article - T4S to L1 Classic in which it says
To run a T4S ToneMatch mixer with two L1 Model I or L1 Classic
On the T4S ToneMatch mixer Pan your inputs left and right as required, but for best results, pan your inputs to one side or the other, but not up the middle
To elaborate on the highlighted section above:
One of the benefits of using the T4S is you can separate the microphones so you don't have all three going to one L1. Pan two microphones to one L1 and the other to the second L1. You want the sound from each microphone to come from only one L1 - the closest one. If you have a singer who stands in the middle, pan his/her microphone to the side with the singer that sounds the most different from the singer in the middle.
Is it possible to use T1 Tonematch instead of t4s ?
Yes, you can, but you lose the benefit of being able to split the microphones.
I have a T1 tone match also. The one with 3 separate I/p and 4-5 are TS inputs (Like the ones you mentioned above). But has only master o/p.
Since you have a T4S - use it. It allows you to split the microphones and with the 3-band ParaEQ in the T4S you have more control if you need to use the ParaEQ to help with feedback issues.
Using the T1 may complicate things by lowering your gain-before-feedback. If you must use the T1, do NOT use a splitter. That can lead to problems with the phase relationship between the two L1 systems.
You can connect things like this
- T1 Master Output to
- First L1 Channel 1
- ToneMatch Preset 00
- Trim at about 4 on the dial - First L1 Channel 1 Line Out to
- Second L1 Channel 1
Use the T4S if you are running to two L1 Classics.
OR
Use the T4S with one L1 Classic, and the T1 with the other L1 Classic.
Connect two microphones to the T4S.
Connect the other microphone to the T1.
Although, if you don't need more than four inputs - it's simpler to use the T4S and pan each input hard to one side.
