T8s digital noise..squawk like sound
Good day...I am having trouble with an intermittent squawk like sound coming thru my t8s.Everything will run great for half a set...then the noise will start.SM 58beta vocal ch1
Audix vx5 vocal ch2
SM 58 vocal thru tc helicon voicelive play ch3
AcousticGuitar thru voicelive playch4
Acoustic guitar 2 ch5 split dirrct
Acoustic guitar 2 ch6..split thru pedal brd..loopers..tcHelicon voicelive3x
Violin ch7
Have isolated all channels when noise occurs.Seems to only happen when all instruments are working.No sign of red or yellow on meter for any of the channels.
When noise occurs I have removed each channel 1 at a time..noise still happens.Does not happen sometimes for 3 or 4 songs then it starts again.
Any thoughts would be greatly appreciated..
Hi codydog19,
I'm sorry you've got this strange squawking sound. You've done some great trouble shooting.
The only thing that comes to mind is to check your firmware.
T4S/T8S Firmware Update Instructructions
and to do a factory reset
T4S/T8S Factory Reset
Note: You'll have to recreate your Scenes.
If that doesn't solve the problem, it's time to call Bose Support.
(U.S. and Canada only)
Other regions
I had a similar problem last year. It was a high pitched digital sounding noise, only occurring when everyone was playing/singing at the same time. The best solution was to check the input levels and adjust the gains. We use playback through two channels (from an iPad). Adjusting the gain to max on the iPad and then to zero on each desk channel prevented this happening.
codydog19 posted:
Audix vx5 vocal ch2
Violin ch7
Mam ten sam problem Ts8 na gwarancji
oddalem do naprawy 2 raz na to samo
Ts4 malo grany
