Recently purchased a pair of L1 mk 2 speakers with a pair of B2 subs.
My question is this: I want use the tonematch t8s through a pair of L1 mk 2 speakers with B2 subs each. I know there is a pair of analogue xlr outs on the t8s but I want to use the cat 5 line out. Can I daisy chain tonematch t4s with t8s to take advantage of the two cat 5 line outs on the t4s to a pair of L1 mk 2 speakers left and right? Will sound on the remaining 2 plus 8 xlr in's be compromised?
I am a novice initially looking to reduce the manual handling with heavy speakers and heavy multi-core stagebox cables.
The ToneMatch port on the T8S is for power and firmware updates only. You cannot use it to send digital audio to an L1 Model II Power Stand or another ToneMatch mixer.
You can't daisy chain the T4S with the T8S using the ToneMatch (CAT-5) ports.
You can daisy chain at T4S with the T8S using the analog connections.
Connect the T4S analog outputs to the T8S Aux inputs (channels 9 and 10).
This gives you twelve channels total with no compromise in the sound.
Many thanks.
That applies to most of us here, so you are in good company.
One of the things I’ve determined is, it's far higher to run the Bass guitar in a single L1 and the Kick drum into every other as you can see. There is documentation about this in here somewhere. I could be putting the kick in with the vocals and the bass in with the rest assuming they both have as a minimum 2 b1 each.
