Hey Flyingpigsound!
The T8S ToneMatch Mixer has a designated Mono Output located at the top left, which can be used exactly as you described. see the below image of the connections for reference:
You would not need to do any alterations such as panning, just connect a standard 1/4" TRS Cable from the Mono Output to a channel input on your L1 1S, and power the mixer with its independent power supply.
Sounds great into my single L1S w/ B2 module!
if I want to add a second L1S for a full electric rock band, do I just run the other out to that ...no need to pan?
I’d only be mic’ing two vocals, a kick drum, and maybe the bass guitar
Hey Flyingpigsound,
To output to two L1 systems, connect from the stereo L&R outputs on the T8S. If your channels are all panned centrally, the two L1 systems would play the same audio as each other.
