Hello drummers and low-frequency dependent musicians (most everyone).
Ever want to give your L1 Compact a pair of big ones?
Here’s what I did today with a pair of Big 10" Woofers.
See it on YouTube.
Both B1s and the B2 bass module sounded good to me. (Just through my PC speakers.) I would have liked to have heard the same track, just played through the L1 Compact (without the bass modules) for comparison’s sake.
quote:I would have liked to have heard the same track, just played through the L1 Compact (without the bass modules) for comparison's sake.
Yes, I thought of that...later!
Another thing I overlooked was changing the crossover point when switching to the B1s, I left it on 250hz.
When I used the Compact w/2-B1s at my gig with the acoustic drumset, I used 375hz.
That might have made a difference.
Still, I just wanted to show that you can tell the difference pretty readily between B1s and a B2.
I heard lots more fullness and power, and feel confident about using this set up live w/E-drums.
Very cool demo, and yes the difference even just using headphones on my laptop was quite obvious. You’re gonna get a ton of mileage of the B2 aren’t you?
Sounds good!
Drumr. In your video I noticed you only used one crossover device and I also noticed it only had one input for
the high and one for the lows with one Compact. My question is if I run two Compacts in a stereo configuration
will that one device still do or will I need to purchase two of them (one for each Compact)?
Should I just purchase a stereo cross over to achieve that. Maybe something like a DBX Driverack. I have never
used a crossover before, but I am going to start.
Hi kenkenni,
For two Compacts, in stereo, you would need two SX21s, or a dual channel crossover.
They make lots of rack mount crossovers.
Personally, I didn’t want to get into a rack device, trying to keep is small/light/simple.
You could use Y cables OUT of the SX21, but then you’d be running mono.
Thanks! Checking my options now.
Hello the YouTube video is unavailable.
I really need help... Because I own a L1 Compact and Want to add extra base with B1, and I'm finding some challenge to find the right gears to have this setup working.
