Tone control for Companion® 2 Series III
am considering buying
Companion® 2 Series III speakers for my computer.
Is the tone, treble and bass, adjustable for this speaker?
Bose product name
(Quiet Comfort Earbuds, NC700, Portable Home Speaker, etc.)
Country
(1.0.7, 4.8.1, 1.7.0, etc.)
(4.1.1, 13.0.2, etc.)
Where do you run into the issue?
Hello maintman18,
Thanks for your question.
The Companion 2 III features a simple volume control dial. There is nothing in the way of hardware-based EQ control. You may, however, use software-based third party EQ solutions to adjust bass and treble.
I hope this helps!
Use the audio cable to make this connection. Insert the stereo mini plug at one end of the cable into the mini audio out jack on your computer. Insert the two plugs at the other end of the cable into one pair of the AUDIO INPUT connectors on the right speaker.
upsers
