I have recently acquired a tonematch to go with my Compact.
A couple of questions:
1. i have two acoustics & two mics, what’s the appropriate channel input set-up on the T1 to accomodate a duo using this set up to perform as a duo?
2. The two acoustics I use are a Larrivee D-04 with an active Fishman Plus Piezo & a Larrivee D-05 with an L.R Baggs Active M1 A.
What are the best selction for the guitars?
Thanks.
Hi Bobby,
Just flying out the door.
T1®
Channel 1 vocal microphone
Channel 2 vocal microphone
Channel 3 guitar
Channel 4 guitar (note - you will have to run the input trim higher on this than on Channel 3, but that is okay and of no consequence).
Gain Staging a Microphone with the T1® (same principles apply for guitars too)
Please watch the short video below. It is for the Model I, but the principles are the same.
–== click the picture ==–
Unfortunately there is no video for doing this on the T1® but the ideas are equally applicable.
Use the same microphone technique Steve describes in the video.
The colors on the T1® are a little different because the T1® trim uses 3 colors. You want to have a good solid green signal with occasional flickers of yellow.
If you are seeing flickers of red, turn down the trim.
For more detailed notes see: T1® Gain Staging.
Presets - for the guitars - Please see: what I do with my Larrivee and Morgan guitars
Thanks for taking the time, I’m going to take a run at it this weekend
