Tonematch T1 as audio interface and direct monitor
Hello friends,  I have a problem and I don't know how to solve it !!
Here using the Tonematch T1 as audio interface for the first time and connecting the Tonematch to computer, everything is ok. I connetc the guitar to one of the channels but I am listening the direct signal of the guitar  plus the signal coming from the USB with the effects and plugins from the computer. I just want to hear the signal from the computer and not the guitar direct signal. In other words, I need to hear the sound coming from the USB and not the direct monitoring. I don't know what to do, and if is possible to avoid the direct monitor in Tonematch.  Thanks so much !!
Hi JorgeOn,
Thanks for posting, welcome to the forum!
Which program/DAW are you using on the computer to record from the T1?
Also, are you monitoring from the T1's output, or the computer's output?
Thanks so much for your answer Dylan.
I am using Logic Pro and Cubase 10.5 in a MacBook Pro
Until l now I have been monitoring from Tonematch master output.
Maybe I am doing something wrong...
Hi JorgeOn,
Thank you for confirming. If you have the T1 set as the input and output device, I recommend turning off input monitoring for the track you're recording to in Logic/Cubase.
Alternatively, you can set the output device as 'Built-In Speakers' in Logic/Cubase, then connect the MacBook's headphone output to your monitor speakers/headphones instead.
Let me know how this goes!
