ToneMatch Updater
The ToneMatch Updater application replaces the L1 Updater.
Use it to update the firmware on your T1/T4S/T8S ToneMatch mixers. There's a new user interface and it works with Windows and macOS.
You can see it in action in the video below.
Get the application and firmware updates for the T4S/T8S here
What version do you have?
On your ToneMatch mixer
  • Turn the Rotary Selector to Prefs
  • Turn the Menu selector to Versions
  • Press Select
  • Read the version number
If you have a T4S/T8S make sure you have firmware version 1.1.4 that was released in November 2018.
If you have a T1 and the firmware is 1.8, you don't need to do an update.
So, is version 1.1.4 the current version for the T8S?  Your wording above confuses me because you are advising us to update if we haven't updated since November 2018 (version 1.1.4).  I have NOT "updated my firmware since November 2018 (version 1.1.4)" because I already have that version loaded.  I believe it would be clearer if you had said "if you have not updated your T4S/T8S with version 1.1.4 (released in November 2018), then you should do that now."   Please clarify.  Thanks!
Thanks Rotnick,
I have updated the text in my post above.
thanks for your patience with us.  That definitely clarifies it for me.
@ST My T1 says the version is 1.8, so I guess I don't need to worry about an update.
Hi ST. When I got my T8S back from Base repair, there was a note in the box that said unit has been checked and all updates installed. So when I turned on the T8S it still has 1.4 Then I went to check my TI and it shows DSP Firmware 1.8, Power stand 1.5. Remember I am using B2 for subs so I'm pretty sure I will need 1.8 for them in order to use all options on the back of the B2 and according to the B2 manual. **** I'm having fun.
Hi Chuckm,
Everything is up to date.  The firmware versions are different for different devices.
Chuckm posted:
T8S: The latest firmware is version 1.1.4
T1:  The latest firmware is version 1.8
L1 Model II Power Stand: The latest firmware version is 1.5
For those reading along - if you have L1 Model II Power Stand version 1.4 you have the latest user-installable version.
trying to update my t8s firmware using a macbook air. Present version is 1.1.0 . I download tonematch updater MAC and unzip. I click on tonematch updater. It takes me to an update button to update my t8s 1.1.0. I click it and it takes me to a new folder D with a greyed out tonematch updater. I can't progress beyond there. This is very likely operator error but I can't figure it out. Thanks
Hello jeff14797,
This might be the issue (not sure):
If you haven't already, be sure the "T8_Update-master-v1.1.4-25adfea.bos" file (the actual firmware file) is in the same folder as where the updater software was installed to.  Otherwise the updater program doesn't think it has anything to process.
I hope that helps!
