I purchased a soundtouch 300 Soundbar and connected via hdmi to my TV. Sounds great and I wanted to add surround speakers so I bought 2 virtually wireless power adapters for my Bose cube speakers and attempted to pair them to the Soundbar. Following the steps in the manual, the lights flash on both the Soundbar and wireless adapters and after a few minutes the adapters are solid white which means connected. The light on the Soundbar doesn’t turn white, but amber which if I understand correctly is the adapters are set to the same side (l or r). I have tried unplugging one of the 2 wireless adapters but still get the amber light on the Soundbar.
i am looking for suggestions, I did update the soundtouch just to make sure that isn’t the issue.
The virtually wireless adapters are about 12 feet from the Soundbar. As noted, the pairing process looked pretty normal and once the wireless adapters went solid white the connection light on the soundbar turned amber.
i do have a Bose sl2 receiver in another room, is that the cause of the problem? Mark
Yes, the adapter has a switch for left or right. They are on different settings. Talking with Bose support, the adapters appear to be functioning properly, and the sound touch 300 connects to them.
I am using the adapters connected to my legacy double jewel cube speakers, which are not listed as compatible; and it would appear that the surround 300 or surround 700 speakers themselves have some kind of circuitry that allows the sound touch / adapter to communicate and properly function.
Since Bose is currently out of stock of the surround speakers, I'm on hold until I can locate suitable speakers, unless somebody knows of anything else to try.
That's correct. Only the Surround Speakers or Surround Speakers 700 are compatible for this setup. Keep an eye on our website for further stock releases.
If you have any questions in the meantime, do let us know.
Once connected please do run ADAPTiQ. If you still don't have any audio from your system, we have some great steps here that will resolve this for you.
