What devices were you using that were affected and what version are they
Currently using Samsung note 20 ultra
have been unable to connect the speakers to wifi or even Ethernet, speakers when first connected worked fine but now are unable to be located by the app
What environment do you experience the issue in? NA
When did you start to experience the issue? Did it work correctly previously? When first connected they would bee to be re connected via the app every 2-3 weeks
Have sent the amp back for warranty with no issues being found, firmware has been updated. Ethernet connection has been confirmed and working.
Sorry to hear you are having issues getting your SA-5 connected back to the app. I will happy to help you.
I see that you have tried some troubleshooting steps already. How far into the setup do you get to before issues start appearing?
Are you able to name the system before an error message appears?
If that's the case, you could try to manually update the SA-5 as it may be running on a firmware version that isn't correctly communicating to the app.
You can follow our manual update instructions on our support website here.
I would recommend that you follow the "Updating the system using a computer and USB cable" from the options in the link above.
The system itself has just come back from repair which they updated all the firmware.
Once I select to connect to Ethernet or even wifi it quickly searches and comes back as no speakers found. The Ethernet port is active as its connected to the TV.
My suggestion is to completely clear your app setting etc from your devices cache and memory. If you followed my suggested steps exactly fair enough. Often people over look one of the steps.
i myself tried removing and re-adding my SA-5's both with the app on my phone and by connecting a cable from my laptop with no luck. I had given up and rebooted my wireless modems for a diff issue and happened to look at the app the next day and all was fine, like the issue never happened. so you could also try rebooting your modems, hopefully it works for you too. Cheers
