I have 4 Soundtouch speakers, (2 10's and 2 20's), and a wave unit, which in the main are fine but currently when you select a given unit the app tells me it cannot be found, or if it finds the speaker it says the NAS is not switched on.
Other programs can connect to the NAS without problem.
The only way I can get the Speaker back online is to unplug it at the wall and then reboot it, although this does not work with the wave unit!
Is there a reason why the Bose app keeps having this problem?
I am up to date with all the software upgrades etc so am running all the latest software
I'm sorry to hear you're encountering some issues with SoundTouch systems not being found. Have you made any changes to your home WiFi network, or the positioning of the speakers in your home, that may have lead to connection issues?
Also, do you have your WiFi network split into a 2.4GHz and 5GHz channel, and if so, which one are your systems connected to? At any point have you tried a reboot your WiFi router to clear any underlying network issues?
Finally, have you tried running the SoundTouch app on multiple devices to see if you notice a consistent issue across all devices not finding your system?
