Please help! I just got my S1 pro today and I have 2 questions from experts.
1 - Do i need to upgrade any firmware?
2- When I charge the battery , where the switch position should be , how long do I have to leave it on charge , and how to check the amount of use from battery? there is template comes with it but i am still a bit confusing.
By the way, the S1 sounds amazing I plugged in Yamaha S950 keyboard and 1 Mic ( one man ban) it sounds so good.
Aloha e Sid. I like to charge my Bose S1 Pro by pressing the top of the power switch to the on position. My experience and education with battery technology is that batteries last longer when trickle charged. I have not yet fast charged my personal Bose S1 Pro. There may be a future situation where I will fast charge between gigs in my car using my 12VDC to 110VAC inverter. I have used this inverter in my car to "top off" my Bose S1 Pro in trickle charge mode. Do you use your Bose S1 Pro on the ground, tilt back, monitor or pole mounted at your one man band gigs, Sid?
I test it on the ground , I plan to get a stand for it soon
