Using 2 Compacts for an Open Mic / Jam
I run open mics (more like jam sessions, nothing planned, musicians will come up to stage and just jump in and join the others. I while the venue is small < 100 people, I figured its better to have 2 compacts rather than 1 1S. (call me silly, but used to having speakers on each side of the room. From what I understand, its a great idea to not have the same sound on both speaker, so with about 6 mics, 6 guitar inputs, keyboard and an occasional other instrument, all set up on my Line 6 M20D mixer, my question is, should I have some of the inputs panned left and some panned right so I will not have the same sound coming out of both. Does this make sense? Am I doing anything wrong? (I figure, since using a mixer, if I find I ever need serious low end, can send the bass and other low freqs. out of an aux out and get a big, heavy (ouch!) sub to schlep along with me.
Bruce
Hi gwampa Bruce,
It sounds like you’re having fun, and that you’ve got a handle on how to use your Compacts well in this application.
Basically:
  1. If you use a mixer, each input should be panned all the way to the Left of the Right. (nothing panned up the middle or anywhere in between).
  2. You want to ensure that each sound source is heard through only one L1®, the closest one.
I think you might enjoy this discussion.
Do you hose an Open Mic show?
Here are some ? ? ? ? ? ? ? for you.
L1® Compact in the wiki
