Hello,
Can I use the MA12, MA12EX or MSA12X without connect them to the DSP controller?
Thank you.
Hello Duke,
Thank you fro contacting us.
For optimal sound a loudspeaker EQ needs to be applied to the MA12 and MA12EX. But you can also use an amplifier with a internal DSP like the Bose PowerMatch, PowerShare, PowerSpace.
The Bose MSA12X is a total different loudspeaker. It is a powered loudspeaker and is steerable. And by default the input is set to Dante (and not to the analog input). So at least for setting it up you need to connect with Dante Controller.
I've noticed you are Live Musician.
Perhaps our Live Music products could be an option for you?
CAS-18580-S8M7B1
