Want stereo keyboard on one L1
I know these are mono and that's fine. Why not just use channel 1 for left and channel 2 for right?
Bose product name L1 pro series
Country Canada
...or use a Y connection
Hi jay bee,
Welcome to the forum! Thank you for your post.
You can use input 1 for the left channel and input 2 for the right, but make sure both L1 channels have the same EQ and volume settings to maintain the balance.
Alternatively, you can connect from your keyboard's headphones output (or its dedicated mono output, if it has one) with a single cable.
Hi Dylan
thanks. That’s what I thought but there is so much talk about the left cancelling out or interfering with the right side when only using one mono array, I wanted to make sure the sound would not be compromized before forking out the 2k for the L1 pro16
