I have a L1s/B2 with ToneMatch. Can I plug in my headphones in my system, or do I have to use it thru a mixer? Second question, can a B1 & B2 be used in series with the L1?
Hi MyMusicGuy,
You can try connecting the QC3 to the T1® ¼ inch jack marked Master Output. You may find that the output is a little low to be useful. It wasn’t intended to be used that way, but I have done it.
I’m not sure what you mean here.
Using the blue cables that come with the B1 and B2…
You can use a single B2 with your Model 1S.
OR
You can use up to two B1s with your Model 1S.
You cannot mix B1s and B2s.
Does that tell you what you wanted to know?
Here are some ? ? ? ? ? ? ? for you.
T1 ToneMatch® Audio Engine
L1® Model 1S
