Will the bose USB dongle work for the normal NC 700 on Windows 10?
Hello, I have the NC 700 and I will like to use it for team calls, such as zoom and Google meet, my laptop is running on Windows 10 with Bluetooth 4.2.
Will the bose USB dongle work for my normal NC 700? For good call and audio quality.
Hello!
Thanks for your question.
Yes, you can purchase the UC dongle separately, this will work with a standard pair of Noise Cancelling Headphones 700, you will just need to pair the two in the Bose Music app when you wish to use this feature.
I hope this helps, should you have any further questions do let us know.
(Ido not work for Bose).  I do not have a 700 (I have a QC35ii) nor the Bose dongle.  But I have both windows 7 and 10 machines (Dell).  My Dell laptop has a mini wifi/bt card made by Intel.  I have had issues with that card and as such purchased two BT dongles.  The first by Insignia did not work for any of my Bose products.  The second, anb SMK Nano, worked fine.  It is likely no longer available but I would recommend any BT dongle that uses "CSR Harmony Drivers".  I would also suggest you stick to a BT 4 device and not 5 (even though they offer backwards compatibility).
As I have no experience with the one you mention here, I can not tell you if it will work or not.
Will it work... It should, although there are better and less pricey alternative (some are given in the threads of this forum).
With good quality... Hmmm the people having tried it are seemingly far from convinced.
