How do I connect my Yamaha MG10XU mixer to the Bose L1 (gen1) to get the best utilization of the mixer and the speaker. I usually have all 4 lines on the mixer being used at one time. How do I connect the 2 and with what type of connector.
Hi Alexander,
Thank you for joining the Community.
- Use the ¼ inch phone jack (Tip-Sleeve) outputs to the PS1 Powerstand, Channels 1 and 2 if you want to use the presets and the Tone and Level Controls on the R1 Remote
OR - Channels 3 and 4 if you don't need the Presets and the R1 Remote.
You can use 1/4 inch Tip Sleeve unbalanced cables, or Tip Ring Sleeve balanced cables, but since the ¼ inch phone connections at the Bose Classic and Model I Power Stand are unbalanced there is no particular benefit using balanced cables.
¼ Inch Tip-Sleeve (unbalanced) to ¼ Inch Tip-Sleeve (unbalanced)
This should work fine.
from the mixer ST OUT on the mixer.
Does that tell you what you need to know?
My unit is a LI compact unit - sorry i forgot to mention that. I only have 2 inputs. One XLR for the mic and one 1/4 inch for the Guitar/LineIn which is on the Bass module.
My Yamaha also looks different
Hi Alexander,
Aha - this is easier. Thanks for the pictures. We have an article that should help.
Please read the introduction and then there's a section about the
Sorry for all the confusion and thank you for the quick response. This helps and I look forward to trying it out. I will provide feedback after my gigs.
