Hi, Limbo.
Thanks for all the great information.
How are you connecting the Tyros 4 to the T1?
- Which output(s) from the Tyros 4?
- Which input(s) on the T1?
Are you using stereo piano patches? How do these compare to other patches that are mono?
The first thing I would do is bypass all the EQ and effects in the T1 and work on getting the best sound from the Tyros 4.
See page 62 in the Tyros 4 Manual where it mentions reverb.
Limbo posted:
ST - Many thanks for the quick response.
1- The quality of the sound is kinda "muddy" and "foggy" and does not contain the same clarity/crispness and presence that I'd expect from the unit. My Shure SM58 that's plugged into another T1 channel has a first class sound.
Okay - that suggests there's too much EQ and Reverb.
2 - I'm using General Keys Tonematch Settings
Press the Category button and it should show "Bypass"
Reverb - Mix 34% Bright 62%
Press the Mix button and it should show "Bypass"
Reverb Type - Type-Medium; Time 1.75; Bal 50%
No change necessary.
Delay, Mod, Comp/Gate - Bypassed
Good.
ParaEQ - Level 0dB; Freq - 1000Hz; Width 1.38oct
Press the Level button and it should show "Bypass"
zEQ - Lo - 13.4dB; Mid - 11.6dB; High - 11.4dB
Press Lo, Mid High and they should show "Bypass"
Turn the Rotary Selector to Comp/Gate
Press the first button and make sure the display shows "Bypass"
Turn the Rotary Selector to Mod
Turn the Rotary Selector to ParaEQ
Good.
I might have overdone the "effects bit", but not understanding the full "effects" story, might not have helped. I just thought there might be a simple combination of T1 settings for the Tyros 4, since it is quite a popular instrument. Thanks again.
At this point, the T1 should be passing the signal from the Tyros 4 through to the power stand unchanged.
How does the Tyros 4 sound now?
Work with the effects in the Tyros 4 to get the best sound you can and then you can tweak things.
Enable the ToneMatch Preset. (better or worse - bypass it if you don't like it)
Try zEQ - but just little changes - probably values of less than /- 3 dB for low, mid, high
Please tell us what you hear.
