S1 Pro battery draining when not in use
Sam Spoons posted:
14 day update:- checked my S1 Pro again this afternoon and after two weeks it is down to 70% and the drain seems to be accelerating as it falls (it took over 10 days to fall to 90%, now, 4 days later it is at 70%). I need to use it on Monday so will have to charge it Sunday but will check it again before plugging it in.
That's pretty much the same as my units and, likely, all the others that have battery drainage issues.
I wonder if any S1's are free from the issue, you would never know yours had it unless you were prepared to charge it up and leave it unused for 10 days or more. Who is going to do that with a new toy?
is there any way to opt out of notifications on this topic.  I'd gladly pay money
tomdavisdotcom posted:
Go to the top of the page and deselect Following this Topic.
Hi TomDavisdotcom, and others.
We've had a lot of posts in this discussion thread lately and you may not have wanted to get all the email notifications.
If you don't want to receive notifications for all the discussion in this thread scroll to the top of this page and stop Following This Topic.
Then use the link below to a different topic where you can subscribe for updates from Bose only.
S1 Pro Battery Drain - Follow this topic for official notifications (no discussions here)
To find out more about notifications - please see Email Notifications and Following a Forum or Discussion
Time to ask again, my dealer has spoken to the UK rep who says there is a fix, Not sure what to do, they have offered repair, replace or refund........
Hi, Sam Spoons.
Bose hasn't made an announcement about global availability for repair. Please work with your local dealer.
Chris M posted:
Warning!
I remember reading a post on here a while back where someone had send theirs back to Bose for repair in the original box, but Bose returned it after repair in a generic cardboard box!
I will be bubble wrapping mine and sending in a regular box as I'd like to keep my original box!
That happened with me. I sent one of my S1 Pro units in for repair in the original box and it was returned in a plain cardboard box. When I called to see if there was any way to get an original box, I was told no. Since I like to keep my original boxes, I will not include them when I ship mine in for repair.
Chet posted:
I keep my S1s plugged into A/C at all times except when transporting them and using them on battery at gigs.  I use them on A/C for practice in my studio almost every day.
Last time I ran them on battery I got three hours and still had battery left.
They're almost 2 years old - semi-early in their battery life.
I'm hoping that whatever defect is causing this problem for others won't bite me here in the middle of the Pacific Ocean...?
The issue does not affect battery life either in use or, apparently due to extra charge/discharge cycles. It only occurs when the S1 is left charged, disconnected from AC and switched off. My replacement (which is now back for repair) took 8 or 9 days to fall below 90% but then another 4 or 5 to lose another 30% charge.
Your charging regime and usage means you will never know if your S1's have the issue (only 10% of owners are reporting an issue but I suspect many, like you, will never discover if their S1 has the problem).
If you continue to use them as you are doing you will be absolutely fine.
Hello ST,
It's good to know that Bose is now repairing the S1 Pro units. Do you think they will get a deluge of S1 Pro units shipped in right away? I'm wondering if I should wait a while before requesting that mine be repaired. Do you think that would be the best way to go?
Michael
Hi Michael,
Please call Bose Support. They can tell you the estimated turnaround time. They should have the latest information about service backlogs or delays.
(U.S. and Canada only)
Other regions
Cheers,
Hi, Everybody.
If you have any questions about the process of getting your S1 Pro system repaired, please contact Bose Support. They are the best place to get information about how your service order will be handled.
Other regions
And now that you can contact Bose Support to set up the repair, you may want to stop the email notifications for this discussion.
Scroll to the top of this page and stop Following This Topic.
Cheers,
ST posted:
Hi, djharryg and DavidE2,
I'm sorry for the confusion.
As soon as I saw your posts this morning, I called our support team.
DavidE2, I see they have already called you back.
djharryg, please expect to hear from the team (check your email if they haven't called you). Or you can call them back.
Thanks for your patience.
Thanks ST!!  Glad I posted here as I didn't think new batteries would fix the issue unless there was some design change to stop the discharge.  Mine are on their way to Indiana for repair.  I hope this one takes!
A couple more points here:  Thanks Chris M for pointing out about shipping original vs a pack box.  You are absolutely correct -- a Bose agent confirmed this for me.
Also, they confirmed that the solution to the drainage problem is both a hardware part replacement and a software upgrade.  They said, operating correctly, the batteries should hold a charge for two weeks or longer.  Neither of mine have ever done that so I'm glad I'm getting them fixed.
If they consider two weeks enough it is not a fix, the batteries should retain their charge for several months, a Li-Ion battery system self discharges at 2-3% a month so worst case it should still be at 60% after a whole year! I hope this is another case of of you rep getting the wrong info
Sam Spoons posted:
You're probably right Sam Spoons. I probably misunderstood what they said. After all, I wouldn't know a Lithium battery from a Lithuanian nunnery.
I'm just glad to get it fixed so I don't have to worry about recharging the battery every time I gig.  I probably still will -- but in case I forget or don't have the time, it's good to know I'll have a bit more breathing room than just a few days before it goes dead.
Hi, Chet.
Chet posted:
If you're concerned, please find a way to leave one of your units off and not connected to AC power for a week or two. If you see a significant drop in the battery charge please contact Bose Support at (877) 335-2673 Monday-Friday: 9:00 AM - 9:00 PM ET
If you mean Hawaii - Bose will cover inbound/outbound shipping (by air of course) on repairs. Your turnaround times should be similar to customers in the continental USA. There's no penalty for living in paradise.
Cheers,
DavidE2 posted:
So far so good!  But I'm surprised my second still hasn't shipped since it arrived at the same time as my first.....
That's good news! Thanks for the update.  I just sent mine out for repair on Monday night.  Hoping for a Christmas miracle and getting it back before the holidays....but maybe by the the end of the year is more realistic.
What are you saying Sam?  This does not sound like your unit was repaired.
No John, the S1 Pro in question was a new from stock replacement for my original S1 which had the battery drain issue. It also had the issue though to a lesser extent than my original S1. It is away with Bose in Belgium as I type being repaired so I won't know if the fix is a success until I have had chance to test it.
My point was that to find out if the fix has been a success we will need to leave our newly repaired S1 Pros switched off for at least three weeks. And even that will not be definitive as the charge indicator in the app only resolves to 10% so, if it is cured it should still be showing 100% after 3 months or longer (expected self discharge <3%/month).
Clearly we buy these things to use them so the likelihood of anybody leaving it unused for 3 months is low. Assuming I have it back in time I will charge mine after my New Years Eve gig and can probably leave it until my open mic on 21/01/20.
